SmartSDR Antenna Management?
Greetings all...
It's winter, which means low band activity from this station. I recently got a new 160m band antenna working very well and have been very active. I also have several receive only antenna out in the yard/field. I am constantly switching my RX antenna while operating 160. I do not use a single antenna configuration for 160, 80 or 40.
Question: What are people using for antenna management from SmartSDR?
I would like to have the antenna selection to be "sticky" and continuously visible without having to go through several mouse clicks to get there. For example having an antenna management sub-panel in right hand side "Radio Panel" would be great! As it is the only options I know about are selecting "ANT" from either the upper left menu or slice flag - the antenna selection from these is either 1 or 2 more mouse clicks away.
This may seem trivial, but for DXing and contesting having the RX antenna selectable with a single mouse click would be a significant improvement in ops efficiency. Can t his be done from SmartSDR or is there a third part software that is recommended?
Thanks!
Chuck
de NJ6D / N7KU
I would think that this could be done with Node-Red. There is several guys here that could help you with.
- 681 The Flea Market
- 219 DAX
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
