How does one switch between two Antennas on one band with 1x3 TGXL?
I have a Spiderbeam and an EFHW-8010, so I have two options for 20 - 10m. Usually I opt for the Spiderbeam on 20-10m, but it would be nice to quickly switch to the EFHW for receive compare or if the Spiderbeam is pointed in the wrong direction. I had thought that perhaps changing the TX Ant under Settings (see screenshot) from Ant 1 (Spiderbeam) to Ant 2 (EFHW) and hitting Save would do the trick, but the TGXL screen flashes red with "No PTT"
1x3 TGXL firmware 1.1.8, 6600 & PGXL
Thanks for your insights.
Ken
Upgrade to firmware 1.1.20
There is no Port B on a 1x3 TG XL. It is one input and 3 antenna outputs. You will need to either usee the touch screen on front of 1x3 tuner or the app to select between which antenna you want to use (of the 3 antennas on 1x3).
The 1.1.20 firmware enables the touch screen for the front of the tuner.
73 Dave wo2x
Perfect. Thank you. Was able to get 1.1.20 from 4O3A web site.
Ken
5
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
