Windows Newbie
I'm experiencing a few problems that I think can be traced back to an inadequate Windows configuration. I am running Windows 11 on top of Parallels 18.3.2 on a 2021 MacBook Pro.
1) Launching SmartSDR v3.5.9 says no radios available (6600, TGXL, PGXL, MacBook & router all attached to dedicated Cisco EN switch). SmartSDR for Mac on the MacBook operates with 6600 & PGXL. (It also gives a CAT warning "SmartSDR CAT requires the FlexRadio Systems FlexVSP driver to be installed. Please reinstall SmartSDR to install this driver" - reinstalling has no effect on this message.
2) Launching TGXL Utility 1.1.8 does not find the Tuner Genius under Local Device tab. Hitting the "Connect" button has no effect.
3) Launching the PGXL Utility 3.6.24 does not find the Power Genius. Hitting the "Connect" button has no effect.
I turned off the Windows firewall and rebooted Windows - no improvement in the above.
What am I missing?
Thanks & 73,
Ken WC6Y
Assume you have a M1 Mac running Windows Parallels. This means you have an ARM-based Windows PC.
First, Windows DAX and CAT will not run on Windows ARM
For the other devices, go to the device configuration for Parallels and check the TCP bridge configuration from Parallels to the Mac. Most use the "Bridge" mode.
Alan. WA9WUD
Thank you Alan for your great insights! Fortunately I do not need CAT nor DAX. Re the Parallels configuration, under Network tab it identified that it had defaulted to "Shared Network (recommended)". Changing it to "USB 10/100/1000 LAN" immediately resulted in the TG being recognized by TG-util, PG by PG-util, and SmartSDR seeing my 6600. Triple-play!
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 195 SmartSDR for Maestro and M models
- 216 DAX
- 391 SmartSDR API
- 87 Aurora
- 331 FLEX-8000 Signature Series
- 987 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 317 Shack Infrastructure
- 222 Networking
- 840 Peripherals & Station Integration
