FRStackWebApi
I need to be able to use 2 raspi pi's for 2 flex radios on the same network. I have looked at the available documentation and I have not found a way to configure the FRStackWebApi.service to only work with a specific ip address.
I have tried changing the service parameters to use the ip address of the radio but that has not worked.
[Service] Type=notify WorkingDirectory=/usr/local/frstack2 ExecStart=/usr/bin/dotnet FRStackWebApi.dll --urls "http://*:5026"
I have also edited the /usr/local/frstack/appsettings.json to the ip of the radio and found out that configures which hosts can access the web api.
"AllowedHosts": "*",
I see where you can add a 2nd instance on another port and that implies to me using 2 radios. However I can't figure out how to point the service to a specific radio ip address.
Hopefully some one here has worked that out.
Regards
Alan, the modifications I made did not work the way I expected. However I was watching the load on the pi when both radios were running and it was not that much more than one radio so I think I am going to go back to the original config.
Regards
I think I have it now..
You do have to change the service to point to the flex radio ..
pi@raspberrypi:/lib/systemd/system $ sudo systemctl status FRStackWebApi
● FRStackWebApi.service - FRStack Web APIs
CGroup: /system.slice/FRStackWebApi.service
└─6661 /usr/bin/dotnet FRStackWebApi.dll --urls http://192.168.1.210:5025
Then you have to go into the flows and set the parameter node to the ip of the radio and also the web socket nodes.
It seems to work fine with this config. Tomorrow I will test turn on the new Flex and see if it ignores the ip data from it.
Regards
Mick
Look at the set of FRStack/Flex Node-Red flows Mark includes in the FRStack download directory.
Mark's example flows have a radio selector and a client selector. Adapt these portions to your flow.
Alan WA9WUD
Thanks Alan, I want to keep the the pi's separate one for each radio due to the overhead I have on the 1st Pi that is a Nginx webserver as well. I will report back tomorrow if it does what I think it will do.
Regards
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
