New Power Genius XL with CAT for Yaesu FTdx101MP
Rejean Leveille
Amplifier received in an excellent conditions with the latest software 3.8.4 installed and after installing the PGXL Uitility software I wanted to connect it with my radio. I could not find any information what to select as Yaesu 1 or 2 or 3. After building my own CAT RS-232c F/F, I finally got it working by selecting (the right baud rate) Yaesu 2 with 8N2.
I know that I could use the Band Data output but if one day I wanted the PGXL Tuner, I will need this CAT connection for the tuner.
All bands working at 1.5 Kw with +/-50 watts
With PG XL 3.8.4 and Tuner Genius 1.1.20, you only need one CAT connection to the amp.
In the TG XL app under Genius Integration, check the box for Power Genius and enter the IP of the amp. The tuner will get frequency info from the amp.
If you add an Antenna Genius then you need BCD info from Yaesu to AG.
73 Dave wo2x
Thank you for this tuner information0
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
