HOW TO USE LINK LOCAL TO CONNECT 6400 TO COMPUTER
My 6400 will not connect directly to computer. It did connect when the 6400 was new, 3 months ago. I wonder what I'm doing wrong or how do I fix it? Or is there another way to connect directly? Thanks for any suggestions. Happy Thanksgiving to all. Ken, K5GI
knewberry
I am confused regarding your previous question on "Using StartLink to connect to your Flex Radio?"
Do you mean you want to connect away from home using SmartLink? If yes, you must upgrade StarLink to a Service with a public IP. And.....you will not use your StartLink Router....because you can configure port forwarding. StarLink will work with third-party routers that allow port forwarding....You will put the StarLink Router in the bridge mode and use the RJ45 adapter to connect to the WAN port of the third-party router.
If you mean you want to connect to your Flex Radio at home using the StarLink Router.....just use your StarLink RJ45 adapter and plug it into a simple TCP switch....Then plug the radio and computer into the switch. Done. You do not need to upgrade StarLink, and you do not need a public IP for local access.
Alan. WA9WUD
Once connected did you cycle the computer and radio?
Hi Knewberry... how are you trying to connect to your radio -- via local network (i.e. wi-fi), via the internet?, via StarLink?
Are the radio and computer in the same room? Can you connect an ethernet cable (CAT6+) directly between them?
Thanks Ronald and Don, Yes Ronald, I have cycled it through several times with no results.
Don. It works fine with T Mobile internet router. I have a Starlink setup I'm wanting to use, but am waiting on an adapter from Starlink. Meanwhile I want to connect radio directly to computer. It worked when I first got the 6400, but now they won't connect. They are side by side and yes, I have a cable connecting them. Should work, but no luck yet. Thanks and have a nice Thanksgiving and weekend, 73 Ken
For a link local connection to work, both the radio and computer interfaces need to be set for DHCP (auto address assignment). When each side times out waiting for an address, they will assign themselves local IP addresses.
Just check that the radio is set for DHCP, and also the PC.
Thanks Ted, I'll give it a try. 73. Ken
Hi Alan, I going to hook it up exactly like you suggested. I have the switch already, and the ethernet adapter is ordered and on the way. Thanks so much for the info. 73. Ken K5GI
- 310 Community Topics
- 565 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 384 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 8.9K Radios and Accessories
- 106 FLEX-8000 Signature Series
- 886 Maestro
- 49 FlexControl
- 840 Genius Products
- 432 Power Genius XL Amplifier
- 296 Tuner Genius XL
- 112 Antenna Genius
- 263 Shack Infrastructure
- 184 Networking
- 427 Remote Operation (SmartLink)
- 132 Contesting
- 685 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 914 Third-Party Software
