Connecting to Starlink internet
knewberry
You must have a public IP address for Flex SmartLink to work.
Upgrade your StarLink to one of the "Priority" plans. Then, from your StarLink admin console, set your IP Policy to "Public IP."
Alan. WA9WUD
Hi Ken, you say that you are not using SmartLink, so I assume that you are just looking to connect your Windows computer running SmartSDR locally to your 6400, right? In other words, you are not trying to connect remotely via the internet, correct?
Len, no smartlink. Just radio. Thanks, ken
Hi Ken, how are you connecting everything?
Normally, you would connect the radio and computer {running SmartSDR) to a network switch using ethernet cables. Sometimes that switch is part of your modem/router (the StarLink box) and sometimes it is a separate box.
If that is how you are connected and are still having problems, you can try "link local" where you plug the ethernet cable from your computer directly into the radio. You will need to power both off, make the connection, then power them both up. Once you have a green light on the 6400, start SmartSDR on the computer and it should find the radio.
If that fails, then it is time to submit a help desk ticket.
Len and Allen, thanks for all the good advice. I'll sure try it out. Thanks again. Ken. K5GI
This post thread might be archived but I am about to set up my flex 6400 at my vacation house that uses Starlink. I have upgraded my account and set IP to public. Is there anything else I need to do in order to use SmartLink with Starlink?
Jonathan, W5GI0 -
Jonathan
Nothing more on the StarLink side, as you say you have upgraded and set up the StarLink for a public IP option.
You cannot configure the StarLink Router. Replace the StarLink router with a router of your choice that allows more advance user configuration. The advance StarLink has RJ45 cable that you use as the WAN to the replacement router.
You must configure your router firewall ports. Flex recommends you use UPnP in the router and Automatic on SmartLink.
Or. if you want, use manual and configure the router ports yourself.
Alan. WA9WUD
Hi Jonathan, I am using Starlink now and it works good. Originally I wanted to connect my computer directly to my 6400, because I didn't have internet. I got that to work finally, but I wanted to connect to the internet when I could. I bought an ethernet adapter from Starlink as my Starlink router has no ethernet port on it. It connects to the router and has an ethernet port on it. From the adapter, go to an ethernet switch, and from the switch run cables to computer and one to the flex 6400. Then it worked OK. This way might be all you need at your location. I don't use Smartlink here so I can't comment on its use. I found that after connecting as described, there was one app I use that wouldn't work. That is an app called EZ PIX, an SSTV mode. I use it to send photos to other EZ PIX users. The fix for that was to use a VPN, Virtual Private Network. EZ PIX works perfectly this way, however some web sites won work properly with VPN on. Just turn VPN off to fix that. I use Avast VPN, it's free. The ethernet adapter from Starlink, cost about $25.00. Before buying an ethernet switch, you could try to use wifi from router to your computer. I hope maybe I answered your question without confusing you too much. Glad to help any time. Let me know if I can help. Good luck, and 73. Ken, K5GI
My Flexradio 6400 is connected to the internet at a remote location using the Starlink residential service. In the current setup, I can only connect to the flex remotely via a slow and often unstable VPN server, because I only have Private IP privileges. If I changed from the Starlink residential to their business priority package, which provides a public ip option, and if I added a configurable router to the Starlink router, does this mean I could connect directly to the flex from 100 miles away using SmartLink?
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
