FLDigi and SmartSDR Frequency Aren't Synched
WK2Y
WK2Y Member ✭✭
I'm getting started using FLDigi (v4.2.00) on my Flex 6500 running SmartSDR 3.5.9. I seem to be copying everything fine, meaning if I tune the slice to 14.070 and enter that into FLDigi, I can see PSK, but if I change the frequency on either, the other doesn't update. What setting(s) am I missing?
Thanks, Happy Thanksgiving, and 73,
Bob
    Hi Bob,
    You need to have the FLdigi config in sync with your SmartSDR CAT setting. In my case, i tis COM8.
    If that isn't the issue, post back and we can investigate further.
  • WK2Y
    WK2Y Member ✭✭
    I see the FLDigi as the process in CAT and both are on COM10 and I have Slice B on the description file and CAT. Odd one. I feel like I have something checked somewhere else that I shouldn't. I presume using Slice B is okay.
  • WK2Y
    WK2Y Member ✭✭
    Never mind. I changed everything to match yours, baud, delay etc, got out and got in and now it works. I just don't know which setting it was, but I suspect the baud: Mine was at 600.
    Thanks and Happy Thanksgiving.
    Yep, that was probably it. Glad you got it working!
