Workaround to SmartLink
Some years ago OK1YA described a workaround solution with MicroTik boxes.
This solution is, for different reasons, not available any more.
Qestion: Is there anyone who has a similar solution ?
If so, I am very interested
Hans SM6BGA
  • N5NHJ
    N5NHJ Member ✭✭✭
    I'm very familiar with the MikroTik routers and I used the native OpenVPN implementation.
    What kind of help do you need?
    73, Max
  • Ha Gei
    Ha Gei Member ✭✭✭
    This could be the way to go
    called EOIP .. for a non public scenario i think it is okay..
    i prefer softethernet, as this is scalable without additional cost ( 1 Raspberry or clone needed at the remote side..can do more things too ).
    Harry
    DL9NDW
  • Lasse SM5GLC
    Lasse SM5GLC Member ✭✭✭
    Harry,
    EoIP looks like a simple way to get a L2 tunnel running. Was watching the youtube video that is somewhat more up-to-date using V7 of Routerboard: https://www.youtube.com/watch?v=0J6h4nNY2kE Even so, the set-up process might be intimidating for a non-savvy TCP/IP-jockey :)
    The Mikrotik EoIP needs two "static" IP and one have to set these up at both ends, and this might lead to problems.
    What Hans really would like is a pre-configured pair of Mikrotik (or any other make) routers that he can plug in at local and remote site, and voila things work.
    I have been exchanging ideas with Hans and trying to find a simple solution, and so far my bet would be runing a SoftEther server/client link (or bridge). Still setting up a SoftEther server is not trivial if you lack some the basic understanding on IP and routing. I have been playing with Mikrotik for some time and still is often overwhelmed with the acronyms and all the options when to solve an issue.
  • sm6bga
    sm6bga Member ✭✭
    Many, many thanks to Harry DL9NDW for helping me setting up SoftEther.
    Hans SM6BGA
