How many versions back do release notes go
Or - do we have to keep all the older version release notes to cover prior upgrades to the software before V3.5.9?
Best Answers
HI @tgiro01 --- to answer your question directly, no, the 3.5.9 Release Notes do not include information on changes made in previous releases. If havng that information is important to you, it would be best to keep copies of the Release Notes from each release as you install it. You may find some of the release notes from previous versions in the documention support library. Documentation – FlexRadio
I'm not sure why you would want to refer back to previous releases, but please be aware that there have been releases lately from Flex where they specifically DO NOT RECOMMEND reverting to previous releases once you upgrade -- due to changes in internal databases, storage techniques, etc.
My concern is that documentation for features gets lost.
When I got my 6600M, it had V3.4.24 on it. I upgraded to 3.5.8, whose features were documented in the V3.5.8 release notes. They are not documented in the 6400M/6600M user guide.
Now I've upgraded to V3.5.9. The features, highlighted in the V3.5.8 upgrade are not in the V3.5.9 release notes, nor are they in the User guide. So, to keep documentation about the features of each release, one must keep the release notes for each release.
I have no intention to step backwards from current releases, except when the upgrade gets ****, or something like that. However I want to keep documentation of new features.
@tgiro01 -- sounds good. As I mentioned and linked, there are previous versions of 'some' of the release notes available in the documentation library. Unfortunately, Flex does not keep a 'running list' of enhancements/bug fixes/etc. for all of the releases.
Flex is 'pretty good' at keeping the SmartSDR User Manual current, but you're right, it can sometimes get out of date, being 2 or 3 releases behind.
For your needs, it would probably be best to print off/download the release notes as they are published and keep them in a binder or folder.
I don’t believe prior version release notes are relevant to upgrading to 3.5.9 from any prior SSDR version.
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 149 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 865 Genius Products
- 307 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 135 Contesting
- 715 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 936 Third-Party Software
