trouble using INRAD 629 or W-1 mics with MacMini M2 Pro and SmartSDR for Mac
thanks Ed N40C
I have a MAC Mini M1 and have a Belkin laptop dock plugged in the USB-C. Needed it for the second HDMI monitor. The Belkin has a TRRS 3.5 mm jack for audio, also known as a CTIA jack. I bought a Y cable at Micro Center that has a TRRS male on one end and a headphone and mic female jack on other ends. I plug my TX audio source into the MIC jack of the Y cable.
In the gear on top bar in SmartSDR for MAC I select the USB audio device as the input (that is how the Belkin appears.
Note - If you use a PTT wired to the radio it will expect the see a mic connected to the radio.
73 Dave wo2x
Dave-- thanks for the quick response. Much appreciated. I'll proceed!
73 Ed N4OC
Dave-- what model Belkin dock are you using or recommend!
thanks Ed
Belkin part number INC004BTSGY
it is the 11 in 1 USB-C dock
73 Dave wo2x
thanks Dave.. Looks like a good one.
I'll check it out. By the way, what mic are you using?
73 Ed N4OC
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 270 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
