FlexButtons V2.0 available
Version 2.0 of FlexButtons is now available at https://www.kregli.com. This version is not compatible with V1.x and any existing Layouts will be deleted!!!!! Sorry, but it was necessary to support some of the new actions that have been included. Read the documentation BEFORE you install this version to get an idea of how it has changed. It remains a free download.
Can you post some of your sample setups on your site??
Most of the ones that aren't just tests are in the documentation. Just click on the doc link and skim through it - there are some at the beginning and several at the end. I'll try to work up some that are like what other users describe. Maybe some users will post theirs???? With the Import/Export feature in V2 they are pretty easy to exchange.
Is there a way to have the command work on the "active slice" For example I have mute programmed but it will only mute slice A . If I were on slice B or C can the command track the active slice so when I was on B or C it would mute that slice
There was an initial bug that forced the active slice to be A. That has been fixed in 2.0.1.0 that is currently on the website (as V2.0). I probably should have made it more visible. Give that one a try - it should fix your issue.
It seems the link above fails for some (many?) folks. If so, you should be able to just type kregli.com into your browser and it should work.
- 654 The Flea Market
- 385 SmartSDR API
- 52 Aurora
- 968 Maestro
- 940 Genius Products
