Can I do remote CW with a key?
trader174
Hi
I am new here. I don’t own any Flex radio yet but as per the title, is remote CW achievable with this system using a key and what would I need to make this happen?
Yes!
There are a couple of ways to key remotely. I have successfully used the simple circuit found on this link:
There is a small program that runs on a Windows PC that keys the rig remotely while giving you local sidetone. This is probably the cheapest solution, but is not the easiest and it requires some soldering.
If you have (or get) a Maestro, it will key the rig remotely. This is the easiest solution, but not the least expensive.
3
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
