Why do Timing setting for RCA TX1 and TX Delay go to Zero on Tune or Xmit?
Nick
Having trouble getting a setting a delay between keying my 6500 and when the RF is sent to my amp. Set both RCA TX1 and TX Delay on the Radio Setup window to several different values from 10 to 200 ms and both values go to 0 as soon as I hit the tun button or key the radio via the MOX button. This causes a "hot switch" fault on the amp which puts it into standby. Is there a way to save these settings?
When you type in the number hit the Tab key to move to the next box. That should then save the values. If you type in the value and exit the screen while cursor still in the box it does not save.
Also try TX Delay instead of TX1 Delay.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
