SmartSDR not installing on Surface pro 7
I cannot get any version of SmartSDR to load onto my Surface Pro 7, it will download and then through all the dialogue boxes, then shuts down when installing. I have tried earlier versions with no luck, i have deleted all other versions, rebooted the computer. Any suggestions
  • Trucker
    Trucker Member ✭✭✭✭
    What version of Windows? Have you had SmartSDR running on the Surface Pro 7 in the past?
    Sometimes Windows Firewall will block installation of programs. You might try turning your Firewall off to see if SmartSDR will install.
  • Kevin King
    Kevin King Member ✭✭
    I tried that with no Luck, I have previously used SmartSDR on this with no issues, It appears to not install any version of SmartSDR will not install
    Kevin
  • Rich M5RIC
    Rich M5RIC Member ✭✭✭
    Tri this, seems to have worked for me and many others.
    1. Right click on the .exe file for the new version where you downloaded it
    2. Select Troubleshoot compatibility
    3. Choose 'Try recommended settings'
    4. Click 'Test the program
    This should then run through the install process as normal.
  • Kevin King
    Rich
    Thanks! that worked, I about pulled out what little hair i have left
    kevin
    KG9FI
