Flex 6700, SmartSDR After 3.5.9 update the PGXL display on Flex no longer populates
Les W6JKA
Flex 6700, SmartSDR After 3.5.9 update the PGXL display on Flex no longer populates the transmitting Power and SWR. The Power Genius Utility does work. Something I'm missing??
Best Answers
While not sure if this would work with v3.5.9, when running v3.5.8 I found that by going into the PGXL utility and select device settings, simply doing a save corrected the situation.
It is an odd fix, considering turning the PGXL on and off did not work nor did restarting the Flex 6600M.
Glad to hear it worked for you..
You’re a genius. Who would have ever known? Fixed.
U can do that or just load the same firmware either fixes the issue.
Thanks. Last issue I’m dealing with is Smartlink not connecting on iPhone but does on iPad
Les Smartlink is down still 9/16 01:37z
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
