Flex 6700, SmartSDR After 3.5.9 update the PGXL display on Flex no longer populates
Les W6JKA
Flex 6700, SmartSDR After 3.5.9 update the PGXL display on Flex no longer populates the transmitting Power and SWR. The Power Genius Utility does work. Something I'm missing??
Best Answers
While not sure if this would work with v3.5.9, when running v3.5.8 I found that by going into the PGXL utility and select device settings, simply doing a save corrected the situation.
It is an odd fix, considering turning the PGXL on and off did not work nor did restarting the Flex 6600M.
Glad to hear it worked for you..
You’re a genius. Who would have ever known? Fixed.
U can do that or just load the same firmware either fixes the issue.
Thanks. Last issue I’m dealing with is Smartlink not connecting on iPhone but does on iPad
Les Smartlink is down still 9/16 01:37z
- 328 Community Topics
- 593 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 158 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 872 Genius Products
- 311 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 438 Remote Operation (SmartLink)
- 135 Contesting
- 721 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 942 Third-Party Software
