Which 1 KW tuner to use with 6400M?
Rapidrob
I need a 1KW tuner for our 6400M radio. Other than the several thousand dollar ATU's which one(s) would you recommend?
I have the chinese kit N7DDC tuner in 1KW Version. No Problems with my 500W linear .
The question is not so much, if it fit´s the 6400 , i must fit the type of amplifier.
One big Problem with autotuners and linears is that for short periods, while tuning, SWR can trip safety of the amp or even **** the transsistors. So , honestly i would not recommend a separate tuner/amp set without communciations inbetween , Amps including tuners are a better chicoe, as the will never tune when the circuit is active.
I havve it narrowed down to the LDG 1000 Pro II tuner for the ease of use and the truly outstanding customer support.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
