Flex 6700, SmartSDR After 3.5.9 update the PGXL display on Flex no longer populates
Flex 6700, SmartSDR After 3.5.9 update the PGXL display on Flex no longer populates the transmitting Power and SWR. The Power Genius Utility does work. Something I'm missing??
Best Answers
  • KH6XX
    KH6XX Member ✭✭
    Answer ✓
    While not sure if this would work with v3.5.9, when running v3.5.8 I found that by going into the PGXL utility and select device settings, simply doing a save corrected the situation.
  • KH6XX
    KH6XX Member ✭✭
    Answer ✓
    It is an odd fix, considering turning the PGXL on and off did not work nor did restarting the Flex 6600M.
    Glad to hear it worked for you..
