Will Radiosport RS55SL SuperLight Travel headset work with Flex 6600 ? What about Heil ?
Folks,
I have the Flex 6600 and I need the heeadset.
Will the Radiosport RS55SL SuperLight Travel headset and the Radiosport Headset cable for SuperLight Travel Headset and Maestro work with it ?
Also, if I want the Heail headset, what type of Heil will work with 6600 ? Any cables are needed to connect the Heil to the 6600 ?
Thank you.
I have a Heil Pro 7 . The cable that are furnished with the headset will plug into the 6600. The 1/8 inch TRS plug goes to the headphone jack and the 1/8 inch Tip sleeve connector plugs to the MIC input. Turn bias off and you may want to enable he 20 dB mic amp. Work fine for me no RFI in the mic at 1.5KW.
I have no experience with the Radio Sport head sets.
Gayle K0FLY
Thank you.
I take it was a Dynamic mike insert, right ?
I have used Radiosport Radiosport RS-60CF head-set for a couple of years at my home station. Have had and used several Heil before that. Have used Heil Pro 7 at another contest station. I prefer my Radiosport way way over any Heil. Heil are good, but Radiosport are Great.
Don't think you should compare those Super Light Travel head-set with Heil Pro 7 and/or Radiosport RS-60. They are totally different type of head-sets. I will probably buy the Travel Head-set for my iPad and PC when remote. But at home, always Radiosport RS-60.
I have bought my Radiosport at Wimo in Germany. I'll see you probably are in Spain. So very convenient buying within EU. I'm very happy with Wimo as supplier of hamstuff.
Gl, 73, Johan
Yes Dynamic on the Heil. I should try the radio sport
Thank you, now I understand.
73 !
Ordered the Heil BM-10 (received and working fine now) as well as awaiting the RadioSport one.
BM-10 was easy to set up using the equalizer. Yet I lack the sound blocks from the outside world, so hope the RadioSport will do better.
I use the Radiosport RS55SL with my Maestro with no issues.
Even my KX3 likes it.
Ian
KM4CQG
Just a note about the Radiosport RS55SL, I've recently tried to replace one of the ear pads and have been told by a supplier here in the UK they're no longer in production. Worth considering if you may need any parts.
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
