mic for iPad?
I've seen several recommendations on headsets, both Bluetooth (Logitech RS55SL, Koss SB45, Bose QC35) and wired (RadioSport RS 55SL), but I'm not sure it's the headset, since I get the same distortion with the built-in mic.
Any suggestions?
I would suggest you check your setting again. I have along with others have used the internal mic on the iPad and iPhone with very good results. I believe you have something else going on to have distorted audio. Just my 2 cents...
https://www.gigaparts.com/plantronics-blackwire-c215-mono-wired-headset-205203-12.html
Cheap and I get great reports on iPad and my laptop.
There are 2 mic gain controls in the iPad app. Check the level of each one.
Make sure that your mic level (as shown on SmartSDR or a Maestro) is not peaking over 0dB. The little peak indicator should never go high enough to turn red. It should peak at around -5 dB.
Sound in Ipad has very high radio gain. While the MIC gain of SmartSDR under Windows is around 70, it is only about 8 on Ipad.
A $25 portable headset sounds very good. The built-in microphone sounds a bit worse (some echo and ambient noise) but still pretty good. Bose 45 via bluetooth sounds very good.
Ignacy NO9E
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 270 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
