Multiple Monitors: Window Apps re-arrange randomly when I turn the monitors off
I want to add some monitor real estate. I'm currently running a 44" wide screen monitor.
My ThinkCenter Tiny P330 I7 computer has a Nvidia video card that can support 4 monitors.
I've installed an additional 4K monitor.
I have all the apps setup where I want them on both monitors
Then I turn them off, come back and turn them back on and the window app's are all over the place. I have the option of remembering window locations under System>Display when a monitor is turned off, however, it doesn't help. My app's are all over the place when the monitors are turned back on.
I like to keep my pc running and just turn of the monitors when I'm done playing radio for the day.
I've upgraded to Windows 11 pro with the same results.
Am I missing something or is this the way it is with Windows and multiple monitors?
Thanks in advance for any ideas.
Rich - N5ZC
Do you have one monitor set up as the 'Main Display' and then selected and set first as 'Extend desktop to this display', followed by the second monitor selected and set also to 'Extend desktop to this display'? If so, I have no other idea but if not, this in theory should make Windows see the entire monitor real estate as one and not give it cause to move program windows. I say in theory because quirks do occur but I have 3 monitors and when they are all set to Extended Display, with that first set on the Main Display, all my programs (and there are 15 of them counting SSDR, CAT, DAX separately) all stay put no matter if one or all of the monitors is turned off.
This, for me at least, has always been a problem. I use WindowManager from DeskSoft to help with it: https://www.desksoft.com/WindowManager.htm0
@EI4KF
Yes to all of your questions. I have my center display setup as the Main Display, and the two other monitors which are physically on either side of the main is setup as 'Extend Desktop'.
Thanks for the tip on the software, I'll take a look at it.
Rich - N5ZC
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
