New 1.1.20 firmware is great
I really love the server mode where the tuner gets the band info from the PGXL! Really makes setting up with a non flex radio easy. I have my 6700 on all the A ports (PGXL, TGXL and AG) and my Yaesu on the B ports. Is really easy to switch back and forth between radios. Well done!
Burch
K4QXX
Downloaded the new Tuner Genius 1.1.20 and my system says it is unsafe. Said okay run anyway and I get these screens:
What's up with this?
Dave
The F-Secure web site (https://help.f-secure.com/product.html?home/internet-security/latest/en/task_4FAC03A45F4D4B35AA713210F65BE116-internet-security-latest-en) explains what DeepGuard is and has this "Tip":
Tip: If you want F-Secure to add your application to the allowed applications list, submit your application for analysis here. Once we have analyzed the program, we will notify you of the analysis results if you have provided us with your contact details.
So perhaps that is an avenue to pursue?
Geoff,
Thank you for a lead to cure this problem. F-Secure will not let me bypass this to even have windows accept it. I will give your link a try and will also try turning F-Secure off temporarily to see if it will let me proceed. I did not have this problem with previous Tuner Genus firmware updates.
Dave
Hello, in my update to 1.2 it failed now I have a tin patch not a tuner.😪
Hi Ezio, I suggest submitting a help desk ticket.
Hi, I solved by restoring the firmware with the procedure described in the manual.
73 of ikgvq😀
- 311 Community Topics
- 567 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 9K Radios and Accessories
- 112 FLEX-8000 Signature Series
- 887 Maestro
- 50 FlexControl
- 844 Genius Products
- 434 Power Genius XL Amplifier
- 297 Tuner Genius XL
- 113 Antenna Genius
- 267 Shack Infrastructure
- 188 Networking
- 428 Remote Operation (SmartLink)
- 132 Contesting
- 687 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 916 Third-Party Software
