Stream Desk Plugin V1.4 for FRStack
Version 1.4 Plugin supports Stream Deck / Stream Deck+ / Stream Deck Pedal.
  • The Stream Deck Plugin is named "com.mkcmsoftware.restcall.streamDeckPlugin".
  • StreamDeck State Action (NEW) provides button press and release event handling.
  • StreamDeck RestCall Action remains for backwards compatibility and custom Rest calls.
  • StreamDeck Toggle Action provides an easy Button toggle action.
  • StreamDeck Level Action provides an easy Button UP or DOWN action.
    • Added selectable + / - sizes.
  • StreamDeck+ Encoder Action provides Dial functionality.
Stream Deck Plugin Instructions
The GitHub site is located at https://github.com/mkcmsoftware/FRStack_Stream_Deck.git
FRStack Website is located at https://www.mkcmsoftware.com/Flex/Index
73, Mark W3II
  • Erik Carling EI4KF
    I am not sure if I simply did not understand the necessary REST Call commands to report levels before these superb enhancements, but displaying same is certainly so much easier now there is the Level Action. One specific example, really handy for me now that AGC-T can be dynamically controlled by SDC, is being able to see the AGC-T level and view its constant optimizations.
    So, thank you Mark for your hard work in keeping your Stream Deck plugin under development with new features and evolving support for the latest types of Deck.
  • David Decoons, wo2x
    Thanks for allowing custom step sizes.
    73 Dave wo2x
