Fuse & SD Card - Next Hardware generation - Locate them on the back of the radio
NEXT Hardware Generation idea -- Both of these items could be located where the user could access them easily. On my 6700 the fuse could be reached pretty easily after removing the cover. On my newer 6600 that is not the case. The 6600 manual says:
“Just remove the top cover and it’s right by the powerpole connector”. Except the filter board covers it! It is not easy to get to the fuse and generally not recommended to try.
I had low voltage lockup problems on my 6700 and although the fuse was fine, the cause was corrosion on the fuse holder. No sure if anyone has seen that on the 6600 but it won't be easy for a user to check and correct.
An SD Card holder for the back panel could be similar to the way SIM cards are accessible on your mobile phone. Theoretically most of the corrupt SD card problems have been fixed but I still see users reporting the issue. Having the SD Card easily accessible would provide some insurance if that memory bug ever comes back.
IDEA: How about making both the FUSE and SD CARD easily accessible from the rear panel. It may not be easy to add this feature to the current hardware ( 6400, 6600) but it would be a great improvement for the NEXT generation. I'd pay the additional cost if it was an option on the existing hardware as well.
This change would make is easy for users to troubleshoot and replace both the fuse and SD Card. The change would reduce radio down time, shipping costs, and reduce support staff work load.
Thoughts?
Would you support this idea?
Do you think an extra $50 is worth adding to a $2K or $3k radio?
Regards, Al / NN4ZZ
Good idea.
John N1JM
GREAT idea!
This type of hardware should always be easily accessible on any equipment. Especially fuses - there are too many option for external fuse holders. Additionally, the SD card could be secured behind a removable panel.
And yes, a $50 bump for these features is well worth it on equipment of this type…..
KF6JS - Tony
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
