Microsoft Windows 11 (Sound & Mic Drivers)
Hello I loaded Smart SDR on my Dell G-3 15 Windows 11 laptop this evening. And when I went to device manager I saw these exclamation icons next to each driver. Did something not install right ? Or is this a glitch with Microsoft Windows 11.
Thank you.
Best Answers
Hi this problem was resolved by submitting a help desk ticket. The issue is with Microsoft Windows 11
Microsoft says this feature is with Windows 10 but when I checked my versions of Windows 10 I did not see this option. But it is with my Dell G-3 15 Windows 11 laptop.
To disable Memory Integrity select Start, type ‘Core Isolation’ into the taskbar, and click on the Core Isolation result to open the Windows security app. From this page, you can turn off the toggle for Memory Integrity. You can re-enable Memory Integrity by simply changing the on/off toggle to "on".
Once I did this the drivers loaded up fine.
Thank you Ken Wells (NM9P) For this information I appreciate the help.
The issue isn't with Windows 11, it's with insecure drivers that have not been updated to support VBS (virtualization based security).
Disabling Core Isolation is a hacky move at best and robs you of a fairly substantial layer of protection you otherwise would have enjoyed. VBS type features have been around since Windows 10, and the incoming security features have been widely publicized and documented in the developer world.
Core Isolation is enabled by default on new Windows 11 machines and fresh Windows 11 installations if the hardware meets the requirements...which generally any windows 11 machine is going to meet due to the more stringent hardware requirements for the OS.
Memory integrity is a critical component that protects and hardens Windows by running kernel mode code integrity within the isolated virtual environment of VBS. Memory integrity also restricts kernel memory allocations that could be used to compromise the system, ensuring that kernel memory pages are only made executable after passing code integrity checks inside the secure runtime environment, and executable pages themselves are never writable.
Flex has promised a few times now to bring their stack into the modern era, but we are still waiting...
- 394 Community Topics
- 670 The Flea Market
- 174 SmartSDR+
- 452 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 79 Aurora
- 320 FLEX-8000 Signature Series
- 982 Maestro
- 953 Genius Products
- 350 Tuner Genius XL
- 129 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
