Configuring manual port forwarding in an ATT fiber modem
rfjohn
Hi All,
I am just now getting around to configuring my Flex-6300 setup for remote operation. I have ATT fiber into the house, and I learned that the ATT modem/router (an ARRIS BGW210-700) doesn't support UPnP, so one must manually configure port forwarding. I see others have had problems with this, so I turned my notes (with personal info scrubbed) into a PDF recipe.
I am new to the Flex Community pages - if there is a way to upload a PDF, let me know and I shall post the PDF.
Hope this may help someone else!
John AF4ZE
John AF4ZE
Hi John
You can post your solution as plain text or if you have a way to host the pdf you can post a link.
There is also a “paper clip” and a “picture” icon at the bottom of the comment entry field that you can use to link to a file on your computer or smartphone to be included when you post a comment.
I include an example below. I used the “picture” icon to add an image from my smartphone
John,
I have the same Internet and router and have it configured with no problems.
1) Connect to your router (mine is 192.168.1.254) and create a custom service for each forward (4993-UDP, 4994-TCP) in Firewall -> Nat/Gaming.
2) Then create an Application Hosting Entry for each service that points to your radio (the serial will be in menu assuming it's connected to your local network).
I have screenshots for each step but don't have the aforementioned paperclip to attach them, so feel free to contact me via email using <my name>@<my call>.com if you have any questions.
73 Phil1 -
Phil - Could you provide more details for each step? When I go in to do the create a custom service for each forward, what ports do I specify? Also on the Application Hosting entry, what do I put in there? It's not obvious to me. Thanks de KF8QL Dave in Grand Rapids, MI0
Got it - Thanks for your help Phil!0
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
