Stream Deck button to open WSJT-X INSTANCE?
Greetings all,
I am looking to open a specific instance of WSJT-x with a stream deck button push.
You know, where you create a shortcut pointing to the wsjt.exe file then append the "--rig-name=****" in the Properties/Target of the shortcut.
This way, I have one shortcut on my desktop for wsjt-x for 144 EME with the flex-1500, another for WSJT-x with the flex 6600.. etc. all on the same computer, all running at the same time (with different cat control and com ports.. etc). Works slick. No reconfiguing of com ports or rig control needed.
However, the "open" command in the StreamDeck software, even when you point it to the shortcut with the associated properties (ex. --rig-name=6600) it doesn't read the altered "target" field in properties and just loads the "generic" wsjt.exe of whatever version you are running, which is either blank of all data, or defaulted to one radios specific settings.
Anyone have a solution?
- Jay N1AV
I have 4 SD buttons for the 4 slices of my 6500, works well and is pretty simple:
WINNER WINNER!!!! Thanks Gary.. Advanced Launcher!😀
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
