SliceMaster not seeing FlexRadio
I had to install SliceMaster (v0.10.8a) in a new computer. I can launch SmartSDR with no problem and connect to the radio but SliceMaster does not see the same radio. I did not have this problem on the previous computer and can't figure out what is different. What am I missing?
Mark K4MV
I figured out that the issue was not having the proper Firewall settings for SliceMaster. I added SliceMaster to the list of "allowed apps" for both the Private and Public Networks. I only had as a allowed app for Private Networks, which didn't seem to work.
Mark,
I was just about to suggest that as the likely cause. I'm happy to hear you found the issue.
Also note that Slice Master v0.11.0c is now available at
https://github.com/K1DBO/slice-master-6000/releases
This newer version wouldnt have helped at all with this particular problem, but it does contain many bug fixes and tweaks.
--Don
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
