What are the settings in Audacity to record my audio after the Flex eq settings.
I am trying to figure out how to record in audacity post TX EQ as well as post proc and bandwidth.
I can record with audacity but it's recording prior to the eq.... settings.. can anyone help me out with this please..
You have to use FDX (Full Duplex) and record on a second slice with an antenna selection differant from the transmit antenna. Using the RX or Transverter Port antenna selection without an antenna connected works good.
Thanks, Larry I will give that a try...
I gave it a shot and yes it does record but what I want is post-audio settings.
I want to have the ability to make changes in my setting, record them, save them, and listen to I can evaluate what I like to save to a profile. If anyone has the settings it would be appreciated.
If you are using FDX transmitting on one slice and recording from the second slice which of course is on the same frequency as the TX slice, your recording is POST-Audio settings.
How do I know Audacity is recording from the second slice? When I play back and listen after I record making many changes I don't hear or see the changes. I must have some path incorrect.
Make sure the slice your receiving and recording from has the same dax RX channel that you have set in audacity. Mine shows DAX RX1. You can also do this with 2 panadapter and a slice in each, my example both slices in one panadapter.
I will give it another look tonight. Looks like your version of Audacity is an older version. Or maybe my version is older. Not that it makes a difference. I see in the DAX you have the Mic Stream off I have it on... I will double-check..
Thanks Larry.. I believe it's working.. now just to try different settings to sound good..
Thank You for your help..
Mark
No problem, have fun.
- 115 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
