3.4.23 and CW Sidetone
Just upgraded to 3.4.23 and the low latency Windows audio is a fantastic improvement. Finally the PC Audio channel is keeping up with the Panadapter. Great work!
But still no CW sidetone on the PC Audio channel. It would be a great improvement - in particular - for CW contesting if N1MM keying generated a sidetone in the same channel as receive audio. I've been waiting nearly ten years now to design out the RemoteRig boxes I use to carry analog audio back to the operating position. Or if I have a guest I'd love to demonstrate CW, but my sending only plays back through headphones on the RemoteRig box. Even when I'm using the internal (CAT) Winkeyer, there's no sidetone on the PC Audio channel.
Is there some hardware limitation that makes CW sidetone on the PC Audio channel impossible? There's so much complexity wrapped around profiles and other configuration that I think the "It's too complicated to support" ship sailed a long time ago.
I would love to hear the news here as I am using same RemoteRig solution for years hoping for a resolve as the Flex remain for me an outstanding radio and I am sure the fellows over there can deal with this. Probably I am not the only one dreaming about this.73
I Just upgraded to 3.4.23 and the low latency Windows audio is a fantastic improvement. Finally the PC Audio channel is keeping up with the Panadapter. Great work! But still no sidetone. I downloaded a program from the Internet called Sidetone. I worked for a while but now has some issues. If anyone else has used this program and had success. Please let me know how you set it up. Thanks in advance. 73 DE N6XT Ron
BTW, I just found the software. Here is the URL:How to Add Sidetone to the Audio Processed in the Software | Ham Cockpit (ve3nea.github.io)
73 N6XT
I would love to have CW sidetone through the PC audio. The software described seems to require you be at the radio anyway. So why not just put the headphones into the radio at that point, **** use the radio's audio rather than the PC Audio?
Would really like to get the CW sidetone through the PC Audio so it could be used remotely as well.
You will get sidetone on the source of keying if you select the "Monitor" button in the CW setup. You cannot get sidetone on the Maestro for N1MM keying. I always plug headsets into the radio (Unless running remote)
- 340 Community Topics
- 609 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 196 FLEX-8000 Signature Series
- 918 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
