How do I get Writelog to send CW with Flex 6400
K2YY
Member ✭
Hi- I would appreciate any help. I have not been able to get Writelog to send CW with my Flex 6400. I have Writelog and Flex on the same computer. It could really be any contest logging program: Writelog, N1MM+, Wintest, etc. I would be most helped by an EXACT list of which settings I should use on the Flex and Writelog. Don't assume that I know anything at all about Windows. Thanks! K2YY
If I remember correctly, you will have to create a CAT port in SmartSDR CAT for the WinKey emulator. Instructions for this are in the SmartSDR and/or SmartSDR CAT User Guides. The COM port that is created should be referenced in the WriteLog setup screen as the WinKeyer port. The WriteLog help files can guide you on how to do that.
I must warn you that I don't know this from experience, as I have a hardware WinKey USB that I use with WriteLog and N1MM+ for CW, but once you have the CAT port created, it should be the same procedure.
73, Craig KØCF
Thanks,Craig!0
- 112 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
