Why doesn't my Maestro connect properly with my 6600M and transfer mic audio?
The 6600M uses a Heil PR781 into the microphone input socket and adaptor for the Heil. The maestro uses the FHM-3 on mic-1, RJ45.
The frustrating part is that it does work on occasion. Why, I don't know. Any help and guidance will be welcomed.
Mike wb6mzs
Did you press the mic control on the right of the Maestro and select the correct input for audio
Yes, I did. Infact I can watch the maestro screen set on M-MIC1 and when I ptt it switches to R-MIC and stays there. In fact at times, it may refuse to stay on M-MIC1 and jumps back to M-MIC. Just now as I was typing this reply it switched on its own to M-MIC1 and stayed there. Its working just the way it should with rf and audio controls working from the maestro. Sadly, this will not last, and it may stay in this correct setting until I shutdown for the night or it may switch back to the incorrect settings before I'm done for the day.0
Hi Mike, do you have different Mic profiles set up? Are you running in multiFLEX mode or are you using SmartControl?
If none of that is the issue, you might want to submit a help desk ticket.
Sucess so far. I created some new profiles and the 6600M and maestro seem to be cooperating so far. Let me run it for a couple of days and verify that it is good.
Thanks for the advice.
What am I doing wrong when I create a mic profile for the maestro m-mic1FHM-3 and then one for mic using a Heil PR781. I save them in the table as I do the tx values. I see them there when I restart but they are not in the default value I need to load.
The mic problem is related to the same problem I have with load profiles. I suppose I'm messing up in the area of what I have to do further to complete the task.
How do I create a TX and MIC profile that will satisfy both the 6600M with the one Global profile? It looks like whatever gets named in one can end up being used for the other unit even though the MIC values for example are different.
- 379 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
