Stream deck and steps
jay KB8O
Has anyone have information on stream deck and the steps it takes in 5 or 10 increments? Is there a way to set for example AGC-T to increase by one instead of 10? Currently using the stream deck plus with no issues but would like to have it adjust a little slower on mostly all dial adjustments.
For audio and AGC-T in single increments you must uninstall your existing REST plugin and replace it with version 1.3 which is found at https://github.com/K9YK/FRStack_Stream_Deck/tree/master/V1_3_1
The only changes in the fork are:
- Radio and Slice AUDIOGAIN now increments/decrements in steps of 1 when rotating an encoder instead of steps of 10
- Slice AGCL now increments/decrements in steps of 1 when rotating an encoder instead of steps of 10
- The version number in Stream Deck is 1.3.1
To install:
- Navigate to V1_3_1/com.mkcmsoftware.restcall.streamDeckPlugin and download the file to your PC
- Open Stream Deck and uninstall your exisitng FRStack 1.3 plugin
- Double click the com.mkcmsoftware.restcall.streamDeckPlugin file that you downloaded and it will be loaded into stream deck
- Access your profile(s) that you use with this plugin and make sure that GLOBAL URL 1 has the correct url to your FRStack3 install.
- You may need to competely close and restart the Stream Deck application on your PC.
This is courtesy of K9YK.
I did have to action point 4 above but once you correct it for one of the REST commands, because its global then all are corrected so overall it is a simple process.
Thank you Erik it's working great !0
- 650 The Flea Market
- 154 SmartSDR+
- 49 Aurora
- 964 Maestro
- 938 Genius Products
