Loose heat sinks in 6600M
wb6mzs
I was moving one of my 6600M to a new location and as I picked it up and turned it some I could hear something rattling loose inside. Opening it up I found two small heat sinks stuck to the side of the case. Not knowing where they came from I filed a work request. In the meantime I found an article on the Flex site detailing a cooling update where two similar heat sinks such as the two I found loose are being removed and replaced with larger ones. My other 6600M already has the updated heat sinks so I figure this one is due.
Am I correct here?
Thanks and 73
Mike w
wb6mzs
Am I correct here?
Thanks and 73
Mike w
wb6mzs
Yes, open a Help Desk ticket and enter the serial number of the radio along with the other information, along with a description of what you found.
Thanks Dave. Already opened one. Just have to add the serial number in it.
wb6mzs0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
