Antenna panel not on screen
Steve KD2OM
I run antenna genius and it selects the switch, asks what mode A, B, or SO2R, then nothing. The app shows in the taskbar but the panel where antenna selection doesn't show on the screen. I have uninstalled the program and re installed it with the same result.
Has anyone seen this and is there a fix?
Steve KD2OM
Hi Steve,
It is possible it is off screen. This can happen if you had dual monitors and then disconnected one.
Try this procedure to see if you can move it back on screen. This is a Windows issue and not app issue.
Thanks Dave, that worked. I didn't think it was an app issue, almost every problem is because of something Microsloth did.
73 Steve KD2OM
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
