Stack3 and Spot use for a 6600M
I have selected the Spots Option menu ,can you help me with the exact fill in the box selections? What and how do you select the URL I have looked at the find spots source and have used http://k2can.us:8088 http://hb9on.org:8000 and telnet://hrd.wa9pie.net:8000. What goes into the SSID field? Do you have any working examples? or where do I find the detailed instructioins.
None of these are producing any spots on a panadapter.
Thank You
Chuck Bigbie N5ANY
Not saying this is your problem but people come to me with "no Spots on Pan from SDC" or same issue with Swisslog (or another Flex client) - are Spots turned on in SmartSDR?
yes spots are turned on and I have filled in servers with no results being displayed. I would like to know how or where to find out how to fill in the blanks on the input window? SSID? correct format of spot server command line ect.
thank you.
OK so refer to the FRStack on board help file. It states:
You can configure up to 4 telnet spot sources to display on the radio's panadapter. The configuration is located in the View - Options Dialog - Spot tab. You must configure your Callsign and at least 1 spot source. You configure a spot source by its IP or DNS name, a colon, port number. eg. "dxc.wa9pie.net:8000". The checkbox before the spot name enables that source. The SSID allows you to assign a callsign suffix number.
- Ignore WSJT-X checkbox will not display a spot when its comments contain "FT & JT" modes.
- Init Command allows you to adjust the "sh/dx/30" command.
- Ignore CW/DIG checkbox will not display a spot when its mode is CW or DIGITAL.
- FRStack handles spot trigger option enables FRStack handling of spot triggers which sets frequency and mode.
- Slice targeting allows FRStack to select active, first for last slice in the panadaptor when triggered.
So, I guess you may have done this. The problem might be that your chosen spot sources are out of date. Try ve7cc.net on port 23. Or maybe you overlooked that 'http' or 'telnet' is not required.
Well Thank You I looked for that and must have missed it.
73's Chuck Bigbie
Smart SDR shows that spots are enabled. I still get no spots unless I have the formatting wrong?
Chuck
From the message above:
"Or maybe you overlooked that 'http' or 'telnet' is not required."
Lose the http:// in lines 2,3 and 4.
BRs,
Tim - k3Tim/7
I did that and I think it is now working. I am running it and will check on it later today.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
