Stack3 and Spot use for a 6600M
crbigbie
crbigbie Member ✭✭
Hi I have been testing Stack3 for my 6600M and I need help on exaclty how to set up, select and configure SPOTS.
I have selected the Spots Option menu ,can you help me with the exact fill in the box selections? What and how do you select the URL I have looked at the find spots source and have used http://k2can.us:8088 http://hb9on.org:8000 and telnet://hrd.wa9pie.net:8000. What goes into the SSID field? Do you have any working examples? or where do I find the detailed instructioins.
None of these are producing any spots on a panadapter.
Thank You
Chuck Bigbie N5ANY
  • Erik Carling EI4KF
    Not saying this is your problem but people come to me with "no Spots on Pan from SDC" or same issue with Swisslog (or another Flex client) - are Spots turned on in SmartSDR?
  • crbigbie
    crbigbie Member ✭✭
    yes spots are turned on and I have filled in servers with no results being displayed. I would like to know how or where to find out how to fill in the blanks on the input window? SSID? correct format of spot server command line ect.
    thank you.
    OK so refer to the FRStack on board help file. It states:
    You can configure up to 4 telnet spot sources to display on the radio's panadapter. The configuration is located in the View - Options Dialog - Spot tab. You must configure your Callsign and at least 1 spot source. You configure a spot source by its IP or DNS name, a colon, port number. eg. "dxc.wa9pie.net:8000". The checkbox before the spot name enables that source. The SSID allows you to assign a callsign suffix number.
    • Ignore WSJT-X checkbox will not display a spot when its comments contain "FT & JT" modes.
    • Init Command allows you to adjust the "sh/dx/30" command.
    • Ignore CW/DIG checkbox will not display a spot when its mode is CW or DIGITAL.
    • FRStack handles spot trigger option enables FRStack handling of spot triggers which sets frequency and mode.
    • Slice targeting allows FRStack to select active, first for last slice in the panadaptor when triggered.
    So, I guess you may have done this. The problem might be that your chosen spot sources are out of date. Try ve7cc.net on port 23. Or maybe you overlooked that 'http' or 'telnet' is not required.
  • crbigbie
    crbigbie Member ✭✭
    Well Thank You I looked for that and must have missed it.
    73's Chuck Bigbie
  • crbigbie
    crbigbie Member ✭✭
    Smart SDR shows that spots are enabled. I still get no spots unless I have the formatting wrong?
    Chuck
  • k3Tim
    k3Tim Member ✭✭✭
    From the message above:
    "Or maybe you overlooked that 'http' or 'telnet' is not required."
    Lose the http:// in lines 2,3 and 4.
    BRs,
    Tim - k3Tim/7
  • crbigbie
    crbigbie Member ✭✭
    I did that and I think it is now working. I am running it and will check on it later today.
