SmartSDR does not open correctly, it disappears.
Hi
SmartSDR doesn't work on my Mac. It was working fine and it stopped working. I think yesterday he did an update to macOS Ventura 13.3. Could it have been that?
Here a video https://streamable.com/6u5zfy
Alfredo WP3C
Hi Alfredo,
no problem here with Ventura 13.3 (Mini M2 Pro), SmartSDR 2.4.06 (upgraded this morning).
Maybe try to reset SmartSDR, I don't remember exactly the procedure but I think you have to press the option key when starting SmartSDR, to confirm… if it helps…
73 Jean-Luc
If nothing else works, Alfredo, you can do the following to remove all preferences and stored information. Be prepared to set up any preferences, etc. you had set up before. Also, you can try removing the app, and redownloading from the app store as a last resort.
Do a search in your Library directories for "de.roskosch.MacRadioApp" and delete the files / directories / folders in the path or with the name, then restart SSDR for Mac.
First suggestion is to reboot the mac
This will clear out any cache issues that maybe in conflict with with MACssdr app.
Doing' reopen' over and over doesnt do a thing except bring you right back to the error condition
side note
if you do a 'report' you will at least see the debug log and get an idea what is causing the crash
i highly recommend rebooting the mac
and
do NOT run xdax and xcat apps before starting mac ssdr
i am running multiple M1 mac (minis and macbook air) all on ventura 13.3 and mac ssdr 2.4.06
only time i have seen a similar conflict is when i run xcat and xdax before starting mac ssdr
and
if it **** xcat/xdax i sometimes need to reboot the mac to clear out command cache
Paul K3SF
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
