Installed 3.4.23 and AM carrier now reduced to 3 watts
I installed 3.4.23 on my windows 10 pc and Flex 6500 and I find that now my AM carrier level has been reduced from 25 watts to 3 watts. This is with the AM Carrier slider set to 50 where it has always been set. If I move the AM Carrier slider all the way to the right, I can achieve 20 watts. If I go back to 3.4.21, I get the usual 25 watts of AM carrier with the AM Carrier slider set to 50.
Manual seems to indicate that carrier should be “about 25 watts” with AM carrier and RF output controls on full.
It should be 25 Watts of carrier when RF Power is set to 100 and AM Carrier Reduction slider set to 100 (no reduction). If this is not the case, then there is still a bug. I will see if / when I update to 3.4.23
I may have misunderstood the relationship between the RF Power slider and the AM Carrier Slider. Prior to 3.4.23 release, if I set the AM Carrier slider to 50, I could adjust the RF Power slider from zero to 25 watts.
If the current behavior of 3.4.23 is correct, I will change my procedure for adjusting the AM carrier / RF Power .
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
