3.4.21: CWX loses focus
Posted this on groups.io...
Version 3.4.21 on Windows 11
I'm working the CY0S pile on 10 CW and using CWX macros a lot. I find that if I manipulate the panadapter with the mouse - slide it to the side, adjust width, move a slice with the mouse, etc - the CWX macro keys no longer work. I have to actually click on the CWX window then they'll work again.
Note that it seems like as long as SmartSDR has the focus the CWX macro keys would work. Not so - manipulating the panadatper keeps the focus on the SmartSDR window but the CWX macro keys stop working.
I'm asking here if anyone has experienced this before I open a ticket.
-Brian n8wrl
That is the way it works. They are separate windows. I generally move both the CW window and the waterfall window out of the SmartSDR grouping when working a pileup. It is a separate window each with there own focus. That is not a Flex thing but Windows
Bill W9JJB
Thanks Bill!
I could swear there is something else going on here. I've been chasing several DX-peditions the past few days so I've left the rig running for hours at a time.
I understand that if I click on my logging software, for example, that F1 will not key the rig - it will do whatever the logging software does.
Sometimes, I can click back into SmartSDR and F1 will send the CWX macro. Sometimes it won't. If I click in the separate CWX window, it will.
The kicker is the intermittent behavior I'm seeing. SmartSDR has the focus. F1 sends the macro. Then I use the mouse to slide the slice, or widen/narrow the slice, or slide the panadapter. After doing that, and not leaving SmartSDR, F1 no longer send the macro. I have to click on the CWX window for it to work. It doesn't always happen and I'm still looking for a pattern.
Other times if I have to wake the computer back up it won't transmit at all, but I think that's a different issue.
-Brian n8wrl
You have to love Windows (or not). I found that after completing the CWX setup with definitions for the F keys, that I should not have the CWX window open at all. With SSDR in focus, F1 sends the relevant CWX key definition. So I can do anything in SSDR and still access CWX with a F key and if CWX has no open window this is consistent. With CWX open then inconsistencies occur, for me anyway. YMMV as they say.
I've written code to manage multiple FlexControls (I have 2 now). It works no matter what app has the focus. I have a USB numeric keyboard. I am going to extend that program to map keys on the keypad to SmartSDR functions, like CWX macros. Then it won't matter what has focus either and I can forget about the F-ing F keys :)
-Brian n8wrl
I am running SSDR 2.4.10 and uses the CWX-F keys all the time when calling in pile ups. I do not have the CWX window open, just the "normal" SSDR, and I can even move mouse over to my web browser and scroll using the mouse wheel, and still push F-key on keyboard to send, as long as I have not moved focus from SSDR.
/Lasse SM5GLC
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
