On a Tuner Genius what does a blank display with a small circle mean?
I was rearranging my shack today when we had a very brief power blip. Related, or not my Power Genius, Tuner Genius, and Antenna Genius all quit working. The displays on the amp and tuner were on, but blank except for a circle thing in the upper left corner. I repowered, checked the network switch and disconnect everything from the network, but had no success in getting things to work. I now have no clue what to do other than take out the shipping boxes. Any ideas what the blank screens mean??
Bill, KB0BK
This function is a new feature of the most recent firmware version and was documented in the release notes. It is used to calibrate the touchscreen device. You should touch the circle, then it will go to another position on the screen — touch it again — and I think it will move a third and final time. Touch it once more.
After that the screen is calibrated and the normal display will once again appear and you should be ready to rock! 🤝
Thanks John. Problem solved. I guess I should read those release notes - would have saved a lot of unnecessary work and stress!!
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
