SmartSDR in MAC & N1MM, CAT & DAX in Windows
Hi
I’m setting up to do the ARRL SSB using SmartSDR in the MAC and DAX, CAT and N1MM in windows. I have in N1MM some Wav that I want to use and found this post from several years ago https://community.flexradio.com/discussion/6944872/vox-operation where KC8R explains how to do it. I did it that way and it works. I use the headset and the Vox activate it self and when I press F1 in N1MM the DAX activates and transmit. My problem is that the transmission starts to cut. For example, in F1 which is “CQ Contest WP3C WP” it’s like the delay shuts down. When I put the VOX in off is better the transmission with the macros. Can some one help me to fix this?
Alfredo WP3C
*fixed up
I’m setting up to do the ARRL SSB using SmartSDR in the MAC and DAX, CAT and N1MM in windows. I have in N1MM some Wav that I want to use and found this post from several years ago https://community.flexradio.com/discussion/6944872/vox-operation where KC8R explains how to do it. I did it that way and it works. I use the headset and the Vox activate it self and when I press F1 in N1MM the DAX activates and transmit. My problem is that the transmission starts to cut. For example, in F1 it is "CQ Contest WP3C WP3C" but it is only transmitting “CQ Contest WP3C WP” it’s like the delay shuts down. When I put the VOX in off is better the transmission with the macros. Can some one help me to fix this?
Alfredo WP3C
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
