SmartSDR in MAC & N1MM, CAT & DAX in Windows
WP3C
WP3C Member ✭✭
Hi
I’m setting up to do the ARRL SSB using SmartSDR in the MAC and DAX, CAT and N1MM in windows. I have in N1MM some Wav that I want to use and found this post from several years ago https://community.flexradio.com/discussion/6944872/vox-operation  where KC8R explains how to do it. I did it that way and it works. I use the headset and the Vox activate it self and when I press F1 in N1MM the DAX activates and transmit. My problem is that the transmission starts to cut. For example, in F1 which is “CQ Contest WP3C WP”  it’s like the delay shuts down. When I put the VOX in off is better the transmission with the macros. Can some one help me to fix this?
Alfredo WP3C
  • WP3C
    WP3C Member ✭✭
    *fixed up
    I’m setting up to do the ARRL SSB using SmartSDR in the MAC and DAX, CAT and N1MM in windows. I have in N1MM some Wav that I want to use and found this post from several years ago https://community.flexradio.com/discussion/6944872/vox-operation where KC8R explains how to do it. I did it that way and it works. I use the headset and the Vox activate it self and when I press F1 in N1MM the DAX activates and transmit. My problem is that the transmission starts to cut. For example, in F1 it is "CQ Contest WP3C WP3C" but it is only transmitting “CQ Contest WP3C WP” it’s like the delay shuts down. When I put the VOX in off is better the transmission with the macros. Can some one help me to fix this?
    Alfredo WP3C
  • WP3C
    WP3C Member ✭✭
    edited March 2023
