FRStacks settings
I am looking for some help with FRStacks3.
I reinstalled Windows 10 on my PC as I was getting computer freezes too often. Installed only Ham Radio SW and can not figure out 2 things with Stacks3. I did Export my settings before Windows reinstallation and Restored from the same file after
- Every time I open Stacks3 it is opening in MRU Bands window. Before Windows reinstallation I have it open on Memory tab and every time I would open Stacks3 it would open on Memory tab, now it is not. Is there anyway to set a default view or make remember on which window to open?
- I cannot make spots to work anymore. Can anyone send me a screen shot of spots menu? I click on "Find Spot Source: tab and tried few addresses with no luck. Maybe I do not set them correctly. Spots on 6600 settings Enabled.
Thanks a lot Larry!
I forgot about that "Initial Tab Settings" = It helped :)
I will try to match your Spots addresses and see what happens.
Appreciate the help!
73! Sergey
One more question
I have only one source for the spots and I see many duplicates. Is there any way to remove duplicates? I maximized SSDR Spot level to 10 just to see how many duplicates there, usually I have it at 3-5.
Thank you
If you check the cluster frequencies of the duplicates I bet they are different. DIfferent people reporting different frequencies for the same station...
I don't see any duplicate callsigns on the screen shot that are exactly aligned vertically.
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
