F 6700+PG+TG on 6m- high SWR on radio's output
Mr Radio
Member ✭✭✭
Recently I fired up my setup on 6m band and note SWR about 2.7 on Flex 6700 output. Everything is fine on other bands. F 6700 ATU is always bypassed when using PG and TG.
Any suggestions where look for a problem?
Tom
Do you have a dummy load to test?
Start with it on output of 6700.
Next on output of PG XL.
Then output of tuner with tuner in bypass, then in circuit and tune.
Try to narrow down where the problem is. Maybe a bad or loose coax jumper.
- 391 Community Topics
- 665 The Flea Market
- 165 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
