Running multiple Copies of Fldigi w 6xxx ??
W2ECK
W2ECK Member ✭✭
edited January 2023 in Third-Party Software
I have Flex 6600, Win 10 PC. Using Slicemaster, I have run multiple instances of WSJTX for FT8 with multiple slices with success.
Now would like to do the same but run multiple instances of Fldigi in the same manner for other digital modes. But when I go to open the 2nd slice using Slicemaster, I get a msg saying configuration already in use.
Does anyone have experience running multiple instances of Fldigi with their 6xxx?
73 Paul w2eck
  • W2ECK
    W2ECK Member ✭✭
    Don Beaudry, the author of Slicemster cleared this up for me, saying he wont add SliceMaster support for a program unless it can run multiple instances.
    If you don't have a configuration for each of your slices, just select the <new> option then type in the name of your new configuration and hit enter. SliceMaster will copy over the Default configuration to create the new one.
    I did this and now have three Slices and three copies of Fldigi running.
    73 Paul w2eck
