Questions about spot API
arodland
in SmartSDR API
- I think that "spot set <id> lifetime_seconds=<n>" sets the spot's expiration to n seconds after the "set" command is run, and not n seconds after the original "spot add" was run. This makes sense. Can I have confirmation please?
- It seems like there is some deduplication of spots internally — a "spot add" with the same rx_freq and callsign as an existing one will return the ID of the existing one instead of adding a new one. Could we know the exact rules that apply so that they can be documented in the wiki?
Thanks!
- Confirmed. The lifetime_seconds just sets a field and a timestamp is created and compared to the original spot timestamp to know when to eliminate that spot.
- The frequency/Callsign combo is considered unique. This note is in the source:
// Check to see if this Callsign-RXFreq combination is already in the DB // If so - treat as a duplicate and simply update the fields in the spot
Both of these clarifications should go into the wiki description, and I'll do what I can to get them updated. Thanks for pointing this out.
3
- 685 The Flea Market
- 102 Aurora
- 994 Maestro
- 970 Genius Products
- 357 Tuner Genius XL
