is an older SD card still compatible?
Buying a 4 year old 6400M with ver 3.0.19 loaded. When I upgrade to the new version is the SD card still compatible? Or will I need to get a new SD card?
Fred, K0FG
The later firmware installation will run some tests that may stress your SD card. If it happens to be the card original to your radio it may fail. But, there have been many that didn't fail. If for some reason it does fail, Flex Radio, usually will send you a replacement if you contact them. You can also purchase an SD card from Flex Radio before you attempt an upgrade as well. If all goes well, you'll have a good backup card for the future.
But, honestly, if the card is only four years old, it is unlikely it will fail.
Thanks James.. I will give it a try and hopefully it will work well.
Fred, K0FG
- 391 Community Topics
- 665 The Flea Market
- 165 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
