I cannot get DAX TX Stream to work with both JTDX and WSJT.
I am trying to transmit with both JTDX and WSJT. I have CAT and DAX Active. I am receiving FT8 Signals no problem on both programs. But for some reason, when I key the transmitter, DAX TX Stream doesn't do anything at all. And I am not getting any output power at all. The DAX TX Stream is just Gray. I don't know what to do and am getting rather frustrated with the whole thing. Does anyone have a solution to how I can fix this? I wanted to say that I am using a 6400M so I am not using the SmartSDR Computer Program to operate DAX.
Mark Griffin, KB3Z
Press the mic gain knob in to bring up the menu. Make sure DAX is enabled. You must also have DAX for Windows running.
Set DAX TX level to 48 and DAX 1 RX to 34. In DAX control panel up top make sure it is set to 6400m if using the front panel of radio. Otherwise set it to the name of the client name you are using (PC name).
Hi Dave!
That did it my friend. Thanks for the help!!
Mark
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
